TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Dbarcle1@gmail.com on September 19, 2017, 04:54:13 AM
I am trying to repair a broken fuel sender unit on my 84K100RS,(the plastic one) have tried several adhesives the latest being a JB weld product. Nothing seems to work, the unit itself cannot be replaced at least here in Australia. Without a solution this bike is destined to be an expensive white elephant for me. Thanks if anyone can help, cheers David
Post some pictures of the part in need of repair. Then an inmate might be able to come up with a solution.
Ok I'll do that asap, thanks
Thanks but wrong ones, wait I'll send a pic. David
Watch this space, 9pm here & I'm not home so will post info soon. Thanks for responding.
:popcorm
Early reference for potential source... http://www.euromotoelectrics.com/
I might have one. What is the part number?
:sip:
(http://www.motobrick.com/gallery/0/1601-200917043851.jpeg)
http://www.k100-forum.com/t1503-fuel-light-unit
Yes that's it, can't seem to send a pic of my own
I think I have sorted this phone, here's 2 pics of my broken sender.
And the other one
It case you can't fix the sender, I wonder if a later tank swap is possible. I know the early ones were secured by a bolt, but besides that does any one know whether a conversion is possible with minimal changes. Dbarcle you might also want to try the BM shop PH (07) 3356 6128. http://bmshop.com.au/
I'm wondering what is wrong with the sender that would cause non operation of the k100? so far I don't see it stated in this thread.
could be very obvious to everyone but me :D
Sender also supplies power to fuel pump & prevents fuel pissing out the bottom, yes tank change I have considered but make that last option
Try the BM shop, he is hard to get on the phone as he is a one man show. Might have to try multiple times, if you are unsuccessful in contacting him let me know and I'll ride down there.
oh I see it now, I thought at first that was a clamp type.
is that some form of plastic? if that is plastic then you can try to reweld it. you need to find out what kind of plastic it is.
you can reweld it all or you can reweld enough to provide strength and structure and use plastic epoxy (Loctite?) to fill in the rest.
the process is similar to metal welding... I suggest you test it out on something first til you are comfortable doing it. its a pretty handy skill for other things.
suggest to use a jig to hold it in place then weld away. pls watch the second link for safety considerations also.
here are a few videos to start you off
https://goo.gl/Zikcoj (https://goo.gl/Zikcoj)
https://goo.gl/jTwC5H (https://goo.gl/jTwC5H)
https://goo.gl/A9wuCM (https://goo.gl/A9wuCM)
HTH, Good Luck.
What does a "clamp type" clamp? Visualization here is illusive this morning.
i didnt know what it was called... :yes but after looking online, i think its called a compression fitting. a cobbled visual is attached.
i hope dbarcle1 can fix it.
Not sure what I'm supposed to do with that, can't block it off, I was kinda hoping someone had a 2nd hand one on offer, that might be my only fix
Try Sydney Kmodelbeamerbits http://www.kmodelbeamerbits.com.au/bmwk-seriesshop.html#!/K-Series-Used-Parts/c/20728236/offset=0&sort=normal or the BM shop Brisbane http://bmshop.com.au/
or Motorworks UK https://www.motorworks.co.uk/vlive/Home/index.php
you can try motorworks.co.uk and see if they have one on stock? price seems reasonable...
http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=6&Q=BA_10_40_KA_60_50_CA (http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=6&Q=BA_10_40_KA_60_50_CA)
or maybe someone can comment if a later tank will work?
