TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Altevogt on September 16, 2017, 09:10:41 PM
Title: Gauging oil level
Post by: Altevogt on September 16, 2017, 09:10:41 PM
Without setting my 91 K100 on it's center stand is there any way of accurately guaging the oil level by observing the oil level in the window?
Title: Re: Gauging oil level
Post by: Blue on September 16, 2017, 09:25:25 PM
You could have somebody sit on it flat footed and hold it still while you stick the gear box and eyeball the engine site glass.
Post by: The Mighty Gryphon on September 17, 2017, 09:26:38 AM
Why not just put it on the centerstand?
Post by: Laitch on September 17, 2017, 09:35:14 AM
Was the center stand damaged? I read in a previous post the side stand on your bike was damaged and repaired. Does your bike still have its lift handle?
Post by: Altevogt on September 17, 2017, 10:28:27 AM
The center stand has been replaced and the kickstand now works flawlessly. I'm the problem, I'm old and getting it on the stand is an iffy process at best.
Post by: Martin on September 17, 2017, 03:34:54 PM
I built a drive in push out front wheel clamp when I did my rear main seal. If you have a welder they can be built or they have been made out of wood. Virtually what you are aiming at is two braced vertical supports wide enough to allow your wheel in, additional tie down straps can be added. Mine resides in the back shed and is a pain to extract but if needed pictures can be taken and posted. it is no work of art and was thrown together out of what I had at the time in a very short time. They can be bought new on line however they have a pivoting action that could make the bike just as hard to extract.
Regards Martin..
Post by: wmax351 on September 19, 2017, 12:13:39 PM
Another option could be an inspection mirror on a rod. Stand the bike up, put the mirror down so you can see. They even have some on telescoping rods, so you could keep it with you on the bike.
Post by: Laitch on September 20, 2017, 04:24:42 AM
Brilliant! Here's a likely candidate (https://www.mscdirect.com/product/details/40310211).
Post by: Blue on September 20, 2017, 05:43:40 AM
Camera phone on a selfie stick. But that is no help for gear box and final drive.
Post by: wmax351 on September 20, 2017, 09:17:37 AM
Drain and refill with exact volumes, plus a slight over fill night be an option.
Sent from my SM-G900V using Tapatalk
