TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: duckytran on September 14, 2017, 12:27:38 PM
Title: Fuel Tank Heat Shield
Post by: duckytran on September 14, 2017, 12:27:38 PM
Any recommendation on an aftermarket product to add heat shield to a K75 tank? I recall seeing a thread where an aftermarket product was being applied to the bottom of the tank.
Title: Re: Fuel Tank Heat Shield
Post by: johnny on September 14, 2017, 01:13:29 PM
you can take your tank to a ceramic heat shield applicator and have them do just the bottom of the tank...
ride dangerously...
Post by: duckytran on September 14, 2017, 01:31:52 PM
ride dangerously...
Thanks, but I recall someone using an off the counter product that has adhesive on one side. You can simply cut to shape and apply it. Prob a cheaper solution.
Post by: Laitch on September 14, 2017, 04:43:01 PM
That'll also protect it from the negligent discharge of a cosmic ray-gun.
Post by: BrickMW on September 14, 2017, 04:53:49 PM
Try Thermo-tec (https://www.summitracing.com/parts/the-13500?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-thermo-tec&gclid=EAIaIQobChMI-8nB68al1gIVAQ5pCh1K_QJjEAQYASABEgKkzPD_BwE)
Post by: BrickMW on September 14, 2017, 05:14:08 PM
EDIT **This product is NOT rated to protect against cosmic ray-gun discharge - be it negligent or otherwise...** :yes
Post by: duckytran on September 14, 2017, 05:22:52 PM
I saw that and may end up using it. I thought there's something out there a little thicker in insulation.
Thanks.
Post by: rbm on September 14, 2017, 06:18:43 PM
Search for Johnny Blanket.  This is basically using a roll of thermal blanket for HVAC applications from Home Depot and cutting it up to place under the tank.  This deflects the engine heat away from the tank and keeps the fuel cooler.
Post by: Blue on September 14, 2017, 07:04:08 PM
I am running Phenolic-Impregnated Carbon Ablator (http://www.spacex.com/news/2013/04/04/pica-heat-shield) on my K1100RS.
Post by: alexg on September 14, 2017, 07:27:04 PM
Search for alumina blanket insulation with Foil; There are several options. I like alumina instead of glass fiber due to EHS considerations.
Post by: duckytran on September 14, 2017, 09:17:12 PM
Your K1100RS hasn't blown up like some of the earlier SpaceX rockets?  :yes
Post by: jay1622 on September 14, 2017, 11:16:24 PM
I've got two layers of this under my tank. Easy to work with, easy to cut, the adhesive works very well, and it keeps its shape.
Thermo-Tec 13575 12" X 24" Adhesive Backed Heat Barrier https://www.amazon.com/dp/B00029KC2K/ref=cm_sw_r_cp_tai_Ew0UzbZQCFJ1H
Post by: duckytran on September 15, 2017, 08:41:39 AM
Thermo-Tec 13575 12" X 24" Adhesive Backed Heat Barrier https://www.amazon.com/dp/B00029KC2K/ref=cm_sw_r_cp_tai_Ew0UzbZQCFJ1H (https://www.amazon.com/dp/B00029KC2K/ref=cm_sw_r_cp_tai_Ew0UzbZQCFJ1H)
Thanks Jay. I'm heading down that same path. Looks like it's the most cost effective option.
Post by: jay1622 on September 15, 2017, 01:04:13 PM
FWIW... Get more than you think you'll need, and clean the underside as absolute best you can. It will fall if you don't, and serve as a blanket for an already-hot motor.
Post by: duckytran on September 16, 2017, 01:26:08 AM
Thanks for the advice Jay.
