TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: bocutter Ed on September 12, 2017, 01:49:33 PM
Title: Monkey Nuttz Orientation
Post by: bocutter Ed on September 12, 2017, 01:49:33 PM
I can't see them going in any other way ... but then it spat out the last set.  :dunno
Title: Re: Monkey Nuttz Orientation
Post by: jay1622 on September 12, 2017, 03:11:15 PM
Yup. That's the way they go.
Post by: Chaos on September 12, 2017, 03:22:23 PM
Is it possible the last set of nuts was defective or maybe really old old stock?  If you saved any of the pieces see if they're crumbly, maybe at least get some money back from wherever you got them.
Post by: bocutter Ed on September 12, 2017, 04:20:28 PM
Euro Motoelectrics. They looked new and the rubber did not seem to be old. They were a lot tighter going in so maybe they are reproductions, and a tad oversize. They were only $12.95USD for the set of 3.
When I ordered from the local BMW dealer I ordered 2 sets ... I thought ... for $46CDN. When I went to pick them up they had only had 2 nuts, "sorry Sir they don't come in sets", so I had to order another nut. $61CDN (+ tax) vs 12.95USD is whack ...
Post by: Martin on September 12, 2017, 04:30:12 PM
Ed obviously they don't know much about Bricks or can't read the parts book. I hope your nutz are good and don't crumble. ( I feel really strange saying that never thought I'd be discussing another guys nutz ) :hehehe
Regards a slightly weirded our Martin.
Post by: Laitch on September 12, 2017, 07:34:16 PM
I believe what might happen during installation of the alternator is a blade of the drive dog will contact the edge of one of the cushions instead of passing between the two cushions and will lever the cushion out of position. That creates slack and then the grinding begins. Lubricatiing the cushions where the blade passes between them is recommended by some, as is using a dab of sealant beneath them to hold them in position that creates as much gap as possible—which won't be much—during careful alignment.
Post by: bocutter Ed on September 12, 2017, 08:40:32 PM
They was lubed ...
Post by: The Mighty Gryphon on September 13, 2017, 10:12:14 AM
I wonder if they were manufactured with EPDM(sorry, I apologize for not knowing what it stands for) rubber.  If they were, you need to be very careful about what you use to lubricate them as EPDM breaks down with some lubricants.
I always assemble my alternator drive with with generous amounts of liquid soap.
Post by: Laitch on September 13, 2017, 11:16:04 AM
Apology accepted. Google still works in the PRV.
Post by: TX brick on September 13, 2017, 12:18:59 PM
When I installed mine they were a loose fit that required gluing them into the cup. I then put silicone lube in the spaces that the drive vanes went into.
Post by: bizzaro on September 13, 2017, 08:57:42 PM
Yes, as stated here, you need to play with them more and use lube before insertion..  That should set you straight? :hehehe
Post by: Laitch on September 14, 2017, 12:58:46 AM
Don't forget! Use high vacuum lube for maximum effect.
Post by: Vespa no more on September 14, 2017, 02:57:42 AM
Some sort of glue (I used silicone / gasket in a tube) to fix them into the cup but also wedge some spacers in between the rubbers (eg 3-5 mm hard board/ plywood, masonite).
Let it dry.
Place a mark on the outer edge of the cup (holding the rubbers) to help with alignment on re-installation.
I fried my rubbers on first attempt.
Second time (as above) very easy
Everything's so logical in hindsight
G
