TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: critter on August 24, 2017, 06:56:09 AM
Title: project k100
Post by: critter on August 24, 2017, 06:56:09 AM
hi from newcastle australia i just aquired old 85 k100 and will try and make a cafe come racer out of her will post  progress as it happens.
Title: Re: project k100
Post by: Filmcamera on August 24, 2017, 07:38:02 AM
Welcome!  You will find lots of help here, it is a great site good luck with your project.
Post by: Martin on August 24, 2017, 05:23:14 PM
Welcome to the asylum from the northern realms.
Post by: MIbrick on August 24, 2017, 05:46:41 PM
Welcome to the big MB in the Cloud. Cafe racer you say. That sounds novel. Post picstures!! (of the bike/progress)
Post by: critter on August 25, 2017, 05:09:07 AM
being a fan of older beemers i do have several cars i found the bmw k100 in shed been stored 6 years so love at first sight and now time to  spend few moments playing.
my job is restoring older cars so hopefuly will help with build i had a audi allroad bi turbo sitting around so started making a turbo setup on her and with a bit of reserch and ringing around just slapped one up on std audi boost 7 lb so tunning should be fine for low boost.i have got the exhaust out rear of back seat thing i am making and have fired her up sounds like old honda 750 quite nice really was amazed.i been doing of night after work for last 8 days so will put pics up as go.will be painting her same as my  e39 msport sherwood green.
Post by: critter on August 26, 2017, 05:54:20 AM
painted couple bits today try get more done tomorrow
Post by: critter on August 27, 2017, 12:41:21 AM
more done
Post by: critter on August 28, 2017, 06:25:03 AM
started last bit of mods the radiator shroud  wrapping around 2 e39 bmw grills
Post by: johnny on August 28, 2017, 08:53:52 AM
nice job... nothing screams cappuccino more than radiator shroud...
Post by: Arktasian on August 28, 2017, 09:21:02 AM
Very creative.
Is that a recycled muffler skin acting as a shield over  turbo?
Curious what you utilized to provide oil feed pressure, on the block (they are fairly void of extra pressure ports and pressure sender is pretty low and restrictive for a tee arrangement - I've been playing with that on my project).
I can't see from the angle of your shots but it appears the oil drain back forward into the valve cover rubber might be fairly level? If so, drainage may suffer going up steep grades. If that does occur, there are clever ways to mitigate the ensuing smoke and/or cartridge seal damage, including an internal check valve/ tee arrangement into the suction bell towards oil pump (RB design) that provides positive suction into drainage hose. That method requires some balance of sizing and check valve crack rating in order to work properly, but all hidden & internal.
Are you going to increase fueling potential?
Good luck on project.
Post by: critter on August 28, 2017, 03:55:16 PM
at the side of head there are two small welsh plugs beside the cams i driled small 1/8 hole in centre of bottom plug and screwed in self tapper and used side cutters to pry out leavering of the side of head came out easy ond clean i used grease on drill bit to colect the drill filings.
then just run the turbo return with snog fit tube with either o ring or sealer.
the standard t gauge adapter was used for oil to turbo running small line to help with correct pressure as not to flood turbo oil sender was placed at bottom of t piece will post pics up tonight
Post by: critter on August 28, 2017, 04:08:24 PM
yes it is the skin of std muffler i cut out the part with the bmw info and desighn rules looks like was std lol.
as far as extra fuel if kept under 7 pound boost fuel should be fine and no need for intercooler as air temp arnt greatly affected at low boost if i want to up boost will use aftermarket fuel sys and get tuned and plum in intercooler
Post by: critter on August 29, 2017, 03:08:58 AM
few pics
Post by: critter on August 29, 2017, 04:14:22 AM
the k's brother
Post by: critter on August 29, 2017, 04:31:56 AM
other side
Post by: Arktasian on August 29, 2017, 11:05:26 AM
That certainly works, but I'm just not happy having the tee hang down in that area where a rock might spoil your ride in a messy way. I figure I'll transition the metric port into a steel 90 fitting/ tube over closer to the cartridge, plus rewire the pressure sender to reside in that area. My cartridge will not mount unlike yours, but slightly higher and inboard (battery relocate into tail)
Cool project, good luck on her!
Post by: critter on August 30, 2017, 02:34:03 AM
point taken i will make small gaurd for it  and avoid rocks
Post by: critter on August 30, 2017, 04:14:22 AM
tonights task is to make a rear gaurd as our transport rules to get rego is needs rear gaurd which i wasnt going to make so quick look on net found couple floating types fixed to diff so i will use the other half i cut for front one and see what i come up with,pics in morning
Post by: critter on August 31, 2017, 05:21:13 AM
update on rear still waiting on led bullet light so carnt finish back of yet but managed to make rear gaurd mount also used for number plate and also found bit of holey stainless so made lower front stone gaurd as mentioned
Post by: critter on August 31, 2017, 05:23:46 AM
rear
Post by: critter on September 01, 2017, 05:06:04 AM
week 2 no bars no tail lights lucky got lots to complete so started on dash which making from my old rear gaurd will try finish on weekend will use tablet and apps for speedo gps extra a start button  small tacho and volt temp gauge will mount from forks back over tank
Post by: Arktasian on September 01, 2017, 08:51:58 PM
I salute your progress and ingenuity, thanks for posting your handy work
Post by: critter on September 02, 2017, 06:29:53 AM
worked on dash but again carnt continue till get long awated bars to complet so started on seat useing the foam from orig and sicaflex to my seat bace and sica makes a good shape finisher if spread corectly.and foam cuts neat and smooth if use electric knife.will post up pics of seat progress tomorrow.
Post by: critter on September 02, 2017, 03:21:03 PM
exhaust tip
Post by: critter on September 03, 2017, 02:52:17 AM
to all the fathers hope your day was goods my dog bought me bag chockies will munch on tonight.
well my brown swade jacket i got from vinnies shop for 10 dollars now my seat cover i am trying to build this um creation cafe racer under 2000 au dollars so far it ows me
bike            1000
h/light            60
blinkers x4      50
paint             220
coat                10
muffler tip       55
gauges           90
tablet(speedo)110
strap-ons             55       if they ever show up
total so far 1595  turbo and other bits i had lying around and made everything i had to with stuff lying around so think will go close to budget time she finished
Post by: bmwpyro on September 04, 2017, 11:59:10 PM
Radiator Grill is a Great Idea! at least the first that I've seen!
May I ask what paint you used for the yellow and what color name? did you use a paint gun?  Thank You.
Post by: critter on September 05, 2017, 01:33:50 AM
the yellow is made from paint shop it is gold really as simmons wheels were painted in and yes  i sprayed from gun
Post by: critter on September 07, 2017, 03:30:05 AM
yaa handle bars showed bit of mission fitting levers over had to run a 1 inch wood drill up the hole so could get on but all good.only problem is were to find tacho wire but will hunt it down
Post by: Laitch on September 07, 2017, 07:41:25 AM
I'm looking forward to seeing this bike stretched out in the sunlight. You're really going for it!  :clap:
The close-quarter photos aren't doing it justice.
Post by: critter on September 10, 2017, 04:19:51 AM
me too
