TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: k on August 15, 2017, 08:20:31 PM
Shortly after I crested some hilly twisties, I noticed the exhaust was deeper. The bike still runs strong, and all cylinders mist water on the header pipes, but the exhaust suddenly developed a deeper tone, not outrageously different, but just different enough for its daily rider to notice. Do mufflers wear out? Did I spring a leak? Did I crack a seam?
While I was squirting water and snooping around for exhaust leaks, I let the bike idle for about 10 minutes. It's about 85 outside. The temp light came on, and I could smell glycol. That never happened before. Quickly shut it off. The smell dissipated, and I didn't see any coolant on the ground. Shouldn't I be able to idle the bike indefinitely? Do I have a fan out?
Thanks for the thoughts.
Yes. Check the blades to see if they'll rotate easily by pushing them with a long screwdriver or dowel. Check the electrical circuit using diagrams from this site (http://www.motobrick.com/index.php/topic,5045.msg31220.html#msg31220).
Easiest way to check for exhaust leaks is to stick a vacuum cleaner hose, set on blow wrapped in a rag up your exhaust pipe. You can substitute compressor air hose wrapped in a rag. Then spray your exhaust with a mixture of water and detergent, if you see bubbles you have a leak.
How many miles on this machine? It's not inconceivable that something internal in the exhaust let go....
Kris,
A ton. Really impossible to know.
The bike still runs strong, ...... but the exhaust suddenly developed a deeper tone,
Congratulations! Your bike finally passed adolescence! :clap:
How quickly they grow up. Bittersweet.
Kris,
Somewhere, on some forum, there was a chart for figuring K bike mileage by how far down the little pyramids on the brake pedal had worn. Probably BMWMOA.org but those elitist a**hole snobs banned my cheap arse for being too cheap to pay their idiotic ransom every year.
Somewhere, on some forum, there was a chart for figuring K bike mileage by how far down the little pyramids on the brake pedal had worn. r.
Well, there's always this thread for preliminary calculation (https://www.motobrick.com/index.php?topic=6252.0).
Found a large hole in top of muffler.
Very interesting. I don't want this to sound personal but I'm sure lots of inmates would love a picture of your exhaust hole, the bricks hole not yours. :nono
