TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: ffbikersa on August 09, 2017, 04:27:01 PM
Checking if the temperature switch on my '93 K 1100 RS - when the needle reach WHICH point at the temperature gauge / dial should the ventilator fan switch on? As it is a heavy heat wave going on in my part of Europe, this question IS important
(https://image.prntscr.com/image/u1m5rumnQm_qpnjZYvvkzw.png)
id fire it up and let it idle till the fan comes on... if the radiator cap blows id shut it off and jumper 12v to the under tank fan connector to see if it moves air...
or... i might do that in reverse order if i didnt wanna blow the radiator cap...
my fan comes on between 2 and 3 and shuts off between 1 and 2... lotts of variables like air lock and low coolant and whack sensor or relay... id jumper it 1st...
its only supposed to be one hundert degrees us there tomorrow... that not hawt...
Here is a thread (http://www.motobrick.com/index.php/topic,10031.msg85540.html#msg85540) that might be of interest to you.
ffbikersa:
I am Acute Toxicity, the Agent In Charge at the DMJ (Department Of Motobrick.com Justice).
The BMI (Bureau Of Motobrick.com Investigations) has confirmed that you violated motobrick.com protocol by not exhausting the search options available at motobrick.com.
This is your notification that another occurrence will trigger sanctions.
The protocol is located here for your review and compliance. (http://www.motobrick.com/index.php/topic,3995.0.html)
A T
ffbikersa:
A T
thanks!!!
