TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: jjs1234 on July 29, 2017, 03:14:37 PM
Title: 20mpg
Post by: jjs1234 on July 29, 2017, 03:14:37 PM
Finally figured out why I'm going through so much gas... I'm getting 20mpg. Wtf... (https://uploads.tapatalk-cdn.com/20170729/7c42dd39d9f0d0b1aa2d94ba1010b729.jpg)(https://uploads.tapatalk-cdn.com/20170729/70b125b59a2ad84a6f7464af9d0807ab.jpg)
Sent from my HUAWEI MT7-L09 using Tapatalk
Title: Re: 20mpg
Post by: jjs1234 on July 29, 2017, 05:11:25 PM
Ran it mostly on the hyw today. 21.3mpg (https://uploads.tapatalk-cdn.com/20170729/b8312f3e4c35a184b40f3ea1ce858596.jpg)(https://uploads.tapatalk-cdn.com/20170729/24ac98d1606be6f9f7ca582c7d141145.jpg)
Title: Re: 20mpg
Post by: rbm on July 29, 2017, 06:28:34 PM
Hard to read because of the glare.  Is the first picture showing 60.2 miles driven and you filled up with 3.274 gallons?  And the second picture shows 50.0 miles for 2.345 gallons consumed?
The programming on your Acewell is way off; it's not the K-bike.  At that rate of consumption, liquid gas would need to be pouring out the exhaust.
Check the tire circumference value and make sure that it is reasonably close to the actual circumference of the driven wheel.  It is critical to get that number right if you want the odometer to register distances correctly and accurately.  Are you using the rear OEM sensor or the Acewell magnetic sensor?  Drive a known distance after resetting one of the trip meters and make sure the odometer is reflecting that distance exactly.  That will either validate the Acewell's programming or indicate the area where your problem lies.
Title: Re: 20mpg
Post by: Chaos on July 30, 2017, 12:02:29 PM
a little more info than a odometer reading and a pump readout would be helpful.  Maybe you're pulling a trailer and mounted a sidecar?  :popcorm
Title: Re: 20mpg
Post by: jjs1234 on July 31, 2017, 12:55:05 AM
I will have to set a Google map waypoint and drive to it. I have the RT final drive and I think a k1100 17in rear rim as opposed to the oem 18in??
Something is off though. Just wondering... If the Speedo speed registers correctly (multiple speed radar verify this) then doesn't that mean the trip meter is correct?
Title: Re: 20mpg
Post by: jjs1234 on July 31, 2017, 12:57:09 AM
Tell me what info you want and I will get it.
Acceleration under 1/3 throttle is more intense than Full Throttle weird enough. Currently at sea level if that makes a difference.
Title: Re: 20mpg
Post by: jjs1234 on July 31, 2017, 12:59:19 AM
Well apparently I can't edit a post, so anyway I'm using the OEM sensor with the BEP 2.0. circumference should be correct if my mph speed it's correct?
Title: Re: 20mpg
Post by: The Mighty Gryphon on July 31, 2017, 01:14:23 AM
Is there a highway anywhere near you with mile markers that you can do a run on to check the odometer?  I have found them to be very accurate, especially if you do a ten mile or longer run.
