TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: 85-K100-Cafe on July 24, 2017, 09:03:02 PM
Hello,
The fan on my 1985 K100RT isn't coming on. I let the bike idle for 10-15 minutes and it did not turn on. All the fuses on the motorcycle are good. Is there a way to pinpoint the issue between the temp sensor, temp relay or a bad fan? I am trying to figure out how can i test each individual part to nail down the issue.
Does the overheat indicator bulb light during that interval? Has it ever lit?
http://www.motobrick.com/index.php?topic=5045.0 (http://www.motobrick.com/index.php?topic=5045.0)
Can you easily spin the fan blades by hand? It's possible that the fan is seized and needs replacing.
1st thing i do is jumper 12v to the fans under tank connector to make sure its running and i feel for air flow...
sometimes the motor runs butts blade donts turn...
process of elimination... i go fan 1st and work backwards to relay 2nd and sensor 3rd...
butts im betting it didnt getts hot enough to trigger the fan in that time frame...
I bought the K as the previous owner was converting the bike into a "café racer" so it doesn't have the factory gauge cluster.
I can spin the fan blade freely by hand
How do I jump the 12v to the fan under the tank connector?
disconnect fan side from loom side... jumper wior from + to connector and jumper wior from - to connector...
Thanks, will try this tonight
This thread (http://www.motobrick.com/index.php/topic,6702.msg45871.html#msg45871)contains the wiring info that may be useful...scroll up for testing options.
