TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Enfield on July 19, 2017, 01:38:24 AM
Hi. I am about to change my Sterling head bearings and fork Oil seals. I have the Haynes manual and it says Fictel or Sachs forks from 1985 and on - mine is K100 1984... and forks are marked Brembo? Is the procedure for bearing removal the same? And am I F.U.B.A.R.. regarding Oil seals? As I Can only find one kind for the K 100?
Thanks in advance
Chr
Bearings changed - as the Way Haynes describes - straightforward. Still havent done seals.
Seals changed - a 10 min job when forks are off.
:2thumbup: Did it all on your ownsome without any interjection. :clap: Well done regards Martin.
