TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: whosyurdaddy on July 15, 2017, 08:12:45 AM
I'm missing the piece that holds the clutch cable into the clutch lever and i'm not getting a good description from the parts fiche . I have a part number 3272123550 , can anyone confirm this is the part for the clutch lever
Not to be sarcastic, but I'm not getting a good description of what you need from your post. If you are talking about the nipple holder that attaches the end of the cable in the lever so it pulls the cable when the lever is pulled, then you are looking at p/n 32 72 1 233 550
Reference number 10:
(http://www.maxbmwmotorcycles.com/fiche/DiagramsMid/B0000674.png?v=12082016)
if you are gonna carry a spare clutch cable you may as well carry a spare nipple too... many times when the clutch cable snaps the nipple will be lost and never found...
some folks will putts some molly on that nipple cause it getts a workout...
+1 I do the nipple with Honda moly every time I do splines(part of my annual winter maintenance festivities).
Gryph thats what I was looking for . I changed my rear shock the other night and didn't realize I was taking pressure off my clutch cable . I've you compressed air across the motor , searched the garage 3 times and no luck so I'll try the local BMW shop .
