TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: mburnley01 on July 01, 2017, 09:27:08 PM
Title: 87 k75 failure to start.
Post by: mburnley01 on July 01, 2017, 09:27:08 PM
so i have been working on my bike i got it to start just fine but the little green button was broken so the button just dove in ans kept the starter turning. I fixed that part. But now when i turn the key, headlights come on, but no diagnostics. None of the cluster will self check. I tried arcing the tabs in hopes it will turn over. Nothing. The fuel pump is not running. The fuses are all fine. Im at a loss.
Title: Re: 87 k75 failure to start.
Post by: Laitch on July 01, 2017, 09:49:26 PM
.  .  . but the little green button was broken so the button just dove in ans kept the starter turning. I fixed that part.
What was wrong with the button and how exactly did you fix it?
Post by: mburnley01 on July 01, 2017, 09:57:37 PM
I drilled a whole in what was left mounted a spring and stuck a washer on what was left and epoxied everything together.
Post by: mburnley01 on July 01, 2017, 10:48:31 PM
Sorry, the top of the button was broken off when I got it. The spring was also gone.
Post by: Laitch on July 01, 2017, 11:25:03 PM
You can see that the assembly is more complex than a washer. I think you'll need to find a replacement switch or fabricate parts that you can see in the following posts.
https://www.motobrick.com/index.php?topic=9094.0
http://www.k100-forum.com/t6814p50-1987-k75-cr#123201
Post by: mburnley01 on July 01, 2017, 11:43:21 PM
Thanks! I'll take a look.
Post by: Laitch on July 01, 2017, 11:44:17 PM
New switch assemblies are $140 plus shipping at EME. (http://www.euromotoelectrics.com/product-p/hbswitch464.htm) Somebody out in the Web might be fabricating only the parts you need, if only you can find them. Used ones will surface but you need to make a list of bike salvage outfits, visit their websites regularly and pounce when you find one.
Post by: Laitch on July 01, 2017, 11:51:10 PM
Here is a site with photos. Use Google Translate to translate the text in you can't read German.
http://technik.flyingbrick.de/images/f/f9/61_lenker_rechts.pdf
