TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: bizzaro on June 23, 2017, 06:52:29 AM
Title: Manual cooling fan switch at fan relay??
Post by: bizzaro on June 23, 2017, 06:52:29 AM
Is there any reason not to hook up a manual fan switch via the fan relay?  Will it have an affect on the motronic?  Or if the engine gets hot enough to signal the fan to come on, and you have it on already, could that be an issue? I am just curious because the popular spot to connect a manual fan switch seems to be at the temperature switching unit.  There must be a reason for that?  I am getting ready to add a manual switch and was going to do it at the fan relay.
Title: Re: Manual cooling fan switch at fan relay??
Post by: rbm on June 23, 2017, 07:13:18 AM
No, there is no reason not to do it. The switch manually simulates exactly what the temperature relay does, so the motorcycle's electronics cannot discern the difference.
as for your questions:
Will it have an affect on the motronic?  No, the Motronic is totally out of the picture.  The fan is controlled only by the temp relay.
Or if the engine gets hot enough to signal the fan to come on, and you have it on already, could that be an issue? No, not an issue.  The switch is wired either to simulate a severely overheated engine, signalling to the relay to engage the fan.  Or it is wired to parallel the relay's contacts and supply power to the fan.  In the first case, the actual water temperature will never get "hotter" than what the switch simulates.  In the second case, if the relay tries to turn the fan on, the switch contacts parallel the relay contacts and nothing untoward happens.
 I am just curious because the popular spot to connect a manual fan switch seems to be at the temperature switching unit.  There must be a reason for that?  Yes, because the temp relay is the brains behind all control of the fan.
Post by: bizzaro on June 23, 2017, 09:51:14 AM
Thanks Robert. I didn't think it would make a difference...........just wanted to be sure.  My electrical knowledge and skill,  is,   well,   nil! :eek:
Post by: Snowman on June 23, 2017, 06:07:50 PM
I have had one for years, no issues.
Post by: Areshuan on July 17, 2019, 01:35:42 PM
Thanks so much Bizarro!
I had been looking for days for the Manual over ride. Finding only instructions for the K100 k75.   I was getting crazy trying to find the Coolant Temp Witch on my K1100.
Just wanted to say Gracias.
Post by: Laitch on July 17, 2019, 03:01:24 PM
I've posted an efficient way to search the site. It's this post (http://www.motobrick.com/index.php/topic,9737.0.html). Paste the term fan override K1100 site:motobrick.com into your browser's search window and see what comes up. If you don't get something the first time change some words. Keep it simple.
